Archiving old machines?
wstewart3
We have a lot of old machines that have not completed a check-in, in quite some time.
I really would prefer not to delete these, as the data could potentially be useful in the future (Such as a FileVault recovery key, or user/program data).
Is it possible to "Archive" a computer? Or is deleting them the only thing JSS can do currently?
9 REPLIES 9
larry_barrett
Put them in a Static Smartgroup, name it [Archive]
wstewart3
Doesn't this still eat up a machine license? At this point, about half the items in JSS are most likely not active anymore, or have been surplussed.
SVM-IT
Only managed machines count against the license. When we retire a machine we add an entry to the comptuer's history including explaining why it was retired and may include a reference to a help desk ticket number.
wstewart3
Ahh I think the problem is I dont know how to mark machines as "unmanaged"? Is there a KB on this? A quick google did not return the results that I wanted.
@wstewart3 When you're looking at Inventory->General for a computer click the Edit button and you can un-check "Allow Jamf Pro to perform management tasks" to make a computer unmanaged
The only problem is that you can no longer add the machine to a static group or search for it if you uncheck that.
No, you can't assign an un-managed Mac to a Group (which makes sense since you have indicated you aren't managing them), but an Advanced Computer Search can still be used to find them and create reports containing them.
I tried a Smart Group too but the "Managed" field isn't exposed. I never thought about a Saved Search but that works. Thanks.
wstewart3
Is there a way to do this using a smart group? Or in Bulk?
