04:39 AM
03:59 AM
Hi everyone,
Just wanted to give a warning to everyone that uses smart mobile device groups to distribute apps. We had a bad morning today in our scenario. Here's what happened:
all apps for secondary school students are scoped to a smart group IOS_SECONDARY_STUDENTS
criteria for the IOS_SECONDARY_STUDENTS is that the iPad belongs to any of these smart groups:
IOS_GRADE6_STUDENTS
IOS_GRADE7_STUDENTS
IOS_GRADE8_STUDENTS
IOS_GRADE9_STUDENTS
IOS_GRADE10_STUDENTS
criteria for IOS_GRADE8_STUDENTS, for example, is the position of the user, which is for example “Graduation2020”
as the school year changes, I have changed the criteria to affect the graduation year change, so devices that were in the group IOS_GRADE8_STUDENTS, will now go to IOS_GRADE9_STUDENTS
even though both groups are in IOS_SECONDARY_STUDENTS, as I changed the graduation year as criteria, all apps and even some configuration profiles started to deinstall, and then proceeded to reinstall
Not really sure why this happened, so we opened up a ticket with JAMF and will post their explanation here. A very dangerous thing to happen for sure!
Posted on 08-05-2016 08:14 AM
@St0rMl0rD Can you detail how you 'changed the criteria to affect the graduation year change'? Is there a chance that a student device was not a member of IOS_SECONDARY_STUDENTS for a short while, perhaps while their Position was removed from one grade level and before they were added to the new?
I have a very similar method and I did not see this when I 'graduated' my students up a month ago.
chris
Posted on 08-09-2016 01:20 AM
Nevermind, it was a mistake in our logic.
Posted on 08-09-2016 05:25 AM
@St0rMl0rD I hate those!! Especially when I plan the logic! :)
Posted on 11-05-2021 01:44 PM
I know this is a bit stale but one suggestion, since grade progresses from year to year but graduation year of a class does not, it may be easier to have a set of grade level apps targeted to a grad year of students, so you'd instead have
IOS_GRAD2028_STUDENTS (today's grade 6 students)
IOS_GRAD2027_STUDENTS
IOS_GRAD2026_STUDENTS
IOS_GRAD2025_STUDENTS
IOS_GRAD2024_STUDENTS (today's grade 10 students)
So the students' device pools stay the same, assuming that those stay with the students, and the apps change out as needed by grade level. Of course, it's always in the tricky logic arrangements...
