06:06 AM
03:03 AM
Casper Imaging now seems to clear any already existing EAs when enrolling a computer.
We pre-create a properly named computer in the JSS using the API, put some extra information (like desired Language and so on) into text-only EAs, and the use Casper Imaging. After Casper Imaging does it's thing, those extra EAs are all empty.
The settings in <https://jamfnation.jamfsoftware.com/discussion.html?id=10828> do not seem to apply anymore.
Has anyone else seen this?
Christoph
Posted on 11-16-2015 06:16 AM
Apparently it's a known issue, the defect number I was given is D-009755. Reach out to your TAM so that they can confirm you are having the same issue for tracking purposes.
Posted on 11-16-2015 07:56 AM
Thanks for the defect number! My TAM verified that D-009755 is indeed the same issue.
