Posted on 04-15-2025 12:03 PM
I Have updated my instance to 11.16 and here are some quick hits that are bugging me.
Posted on 04-16-2025 12:40 AM
Hi @danlaw777 . Thanks for your interest in compliance benchmarks and your feedback. Let me comment those:
Posted on 04-27-2025 10:28 PM
Hi @Tomas_Lukl1 are their plans to support the exceptions.plist so you can exempt some rules from a subset of computers in scope of the benchmark? The JCE supports this with the Compliance - Failed Results Count EA and the Compliance - Exemptions EA.
Posted on 04-28-2025 01:18 AM
Hi @c_kay . Thank you for the question. Could you please describe in a bit more detail what is the use case the exemptions are useful for you?
Posted on 04-28-2025 08:48 AM
I have an open feature request for this https://ideas.jamf.com/ideas/JPRO-I-1278
Here's the situation I face. My creative team needs all our CIS benchmarks except 1. Airdrop. It would be very beneficial if I could go to the CIS rule, click an 'exception' button, and add a smart or static group to exclude it from that specific rule without having to create a whole new set of benchmarks for just one small group. That makes things very confusing and conveluded when trying to assess our security standards.
Posted on 04-28-2025 06:38 PM
For us we need a small number of Macs to have Apple Remote Desktop and SSH enabled but we don't want to have to create a seperate benchmark for them. There might be further exemptions a few users might need in the future and again we don't want to create more benchmarks. The script that Jamf Pro Compliance creates for the Benchmark already supports the Exemption plist its just your Failed Result List EA for the benchmark that doesn't. It reports rules that have been exempt as failures instead of ignoring them.
Posted on 04-28-2025 06:40 PM
Are their plans to be able to sort the rules in a benchmark numerically instead of alphabetically to rule 1.10 comes after rule 1.2 ?
Posted on 04-28-2025 11:01 PM
Actually that's been fixed so ignore.
Posted on 04-30-2025 04:40 AM
Yes, right on Monday! But keep this feedback coming please!
Posted on 04-28-2025 11:03 PM
@Tomas_Lukl1 is their going to be an API for Benchmarks so we can access the reporting data?
Posted on 04-30-2025 01:28 AM
@c_kay yes, creating an API to get reporting data programatically is on our roadmap. Is there anything specific you would expect this API to provide and what would you use it for?
Posted on 04-30-2025 02:01 PM
I'd like the API to be able to get the Rule report data. So the pass, fail, unknown numbers for each rule please.
Posted on 04-30-2025 06:47 PM
Speaking of the Rule report. I've noticed that a rule with 0 pass 0 fail 0 unknown is calculated to 0% Computers passed. I'm think that should be 100% Computers passed otherwise it looks like the rule failed where really it just doesn't apply to any other the Macs in scope.
For example, rule 5.9 Ensure Extensible Firmware Interface Version is Valid
Posted on 05-05-2025 03:59 AM
Good point, thank you for the feedback! Let me look at that and get back to you.
a month ago
Hi @c_kay. Getting back to this topic - just wanted to let you know that we've removed the percentages from rules with no applicable computers in scope to prevent confusion.
Posted on 04-16-2025 05:20 AM
ability to switch coming-EXCELLENT
workaround worked!
and I still dont see the profiles in device management
Posted on 04-17-2025 03:57 AM
@danlaw777 Do you mind sharing your compliance benchmark configuration as well as the profiles section under device management (screenshots incl. rules, if that is ok)? If you can't share it publicly for privacy reasons, please share it via DM to me or open a support ticket. Thank you.
Posted on 04-28-2025 11:58 PM
Hi @danlaw777. A bit guessing about the configuration profiles in device management. You've mentioned that you haven't 'enforce quite yet'. The profiles are only used for enforcing the rules - monitoring is done via a script (executed via a policy, resulting in a filled extension attribute).
Checking our test instance, I can see the profiles used for benchmark enforcement in the computer inventory.
Is this what you've been looking for?
Posted on 04-17-2025 05:49 AM
if you have time, send me a calendar req and I can show you live
04-22-2025 01:35 AM - edited 04-22-2025 01:36 AM
Hi@danlaw777 . Here is my Calendly link. Feel free to pick a time that suits you the best! Thank you.
Posted on 04-24-2025 04:04 PM
I was just looking and is there no way to edit the scope of compliance readiness after it is created? I saw I can edit which rules are enforced but not any scoping.
04-24-2025 11:54 PM - edited 04-24-2025 11:54 PM
Hi @mattjerome . Thank you for your feedback. We are actively working on many improvements to the compliance benchmarks capability - allowing to change the smart group (scope) is one of the items that are on our near-term roadmap. Please stay tuned for updates. In the meantime, as a workaround, you could potentially use nested smart groups feature in Jamf Pro to achieve what you need.
Could you please describe the use case for which you need to edit the scope?
Posted on 04-25-2025 05:16 AM
scoping feature is NEEDED!
1. pilot this configuration
2. post pilot, rescope to all devices
3. pilot next macOS
these are 3 but there are more I know
Posted on 04-27-2025 11:45 PM
This makes sense. Thank you for the context. Ability to edit scoping (by changing smart group) will come very soon.
Posted on 05-06-2025 11:17 AM
Hi @danlaw777 @mattjerome and others,
I wanted to share that editing of benchmark scope (smart group) and mode/type (monitor or enforcement) has been enabled just today. Go check your Jamf Pro instances and let us know if the new capability works well for you!
Posted on 05-07-2025 05:31 AM
this is wonderful!!!
